10-28-2007 01:50 PM
10-29-2007
05:49 PM
- last edited on
07-21-2025
03:03 PM
by
Content Cleaner
Hi MHP,
I suspect that you may have some grounding issue that is causing the noise. If you generate an analog output signal and feed it to the analog input, is the noise gone? Here’s a useful link for wiring and noise considerations.
Calibration is something to consider when concerned about noise. How old is the card? When was the last time it had an external calibration? Internal calibration?
Will you please include the versions of all the software you are using, including LabVIEW, DAQmx, Measurement & Automation Explorer (MAX), and what operating system you have?
Will you please include a screenshot of the noise if none of these suggestions cleans it up?
11-01-2007 03:14 PM - edited 11-01-2007 03:14 PM
Do you have an identical board that you could try in order to verify that it is just this board that is malfunctioning?
@MHP wrote:
The PC, card, and machine are new. I disconnected all external wiring and used a 4-20mA loop calibrator. The signal is still the same amount of noise. I then wired an analog output to one of the analog inputs. The noise was the same or worse. I was experiencing a 0.6mA amplitude on the noise with a constant output. Today I can get a reasonable signal, but then it starts ramping and then rails. Sometimes the signal is an occilation that spans from 4mA to 20mA. My signals incoming are constant.
I even took the PC to another location(my house) and used the analog output to power the analog input. The results were the same noisy signal. I was trying to eliminate the fact that my office may have "dirty" power with harmonics on the lines.
I have the negative on the analog input tied to DC common and the AI GND tied to DC common. I am concerned that there is a problem with the PCI-6238 card. It passes all the tests and has been calibrated.
I have isolated the breakout board from all field wiring and the noise is still eradict. Please offer any assistance.
Message Edited by Mark E on 11-01-2007 03:16 PM
11-01-2007 08:28 PM
11-02-2007 08:38 AM - edited 11-02-2007 08:38 AM
Hi MHP,
One of the easiest and most visual ways to see how signals should be connected is to create a task in MAX. This is done by right-clicking Data Neighborhood » Create New… » NI-DAQmx Task and choosing the type of task (current input). You then choose your device and channel(s). Once it is created, you can click on the Connection Diagram and choose the channels individually to see how each should be wired. For devices with an accessory, you’ll need to choose the correct one (the picture is of the first choice).
Let me know if you have more questions.
Message Edited by Mark E on 11-02-2007 08:39 AM
