I am have an error with the email notification.vi exampl
I am running it over and over again and I am constantly coming up with Error 16502 occurred at 502 5.5.1 Unrecognized command. 13sm329013bwz.10
I have set it so that it reaches the lower limit and it recognizes it but I don't know why there is an error.
(3,184 Views)
There is no description for this error.
Can you explain a bit more in detail what's wrong or the steps to reproduce this?
Christian
(3,176 Views)
Antoher question, have you been able to connect to the mailserver, so if you click test on the dialog to type in the mailserver, does this work?
Christian
(3,174 Views)
