I am trying to find a recovery from transients rate for a 6225 and data on crosstalk
We're coming off an FDA audit with a few issues I have to answer to. Any help would be greatly appreciated.
Recovery From Transients: Rated biopotential signal acquisition on a channel shall be available within 50ms after the channel is exposed to a transient beyond its programmed dynamic range setting but within ±2V.
 Channel Crosstalk: Input signals within the dynamic range (5 micro Vpp up to 750 micro Vpp) and frequency bandwidth (24-240 Hz)
(2,879 Views)
We only spec crosstalk at one frequency (100 kHz), and that value is in the specifications document for the device. However, we do not have specific information in the range that you have specified. We do not spec the recovery from transients, but we may have other related specifications, such as slew rate. I am looking into that and will let you know. -Christina
(2,841 Views)
