I am trying to get analog output from DAQ PCI6024E.
I am trying to get analog output from DAQ PCI6024E. Pins 22 and 55 are supposed to do this, I can read the analog output by a multimeter but it wont make a DC motor work. what can I do?
(2,484 Views)
Please make sure that the output voltage is sufficient enough to drive the motor. You can also try with a different motor if you have, to see if the motor is working fine or not.
Sincerely,
Sastry V
(2,484 Views)
