I don't where connect my RS-485 line into the SCB-68 connector block !
Dear all,
I try to connect an serial line in RS-485 to my DAQ card 6533 through a SCB-68 connector block. My problem is that i don't no wich PIN
i can connect in this box! (I don't see RX+, RX-, TX+, TX- in the SCB-68).
Help me please,
Thanks in advance,
Laurent
(2,945 Views)
The SCB-68 is just a dumb terminal block and the pins are labeled 1 through 68 which correspond to pins 1 through 68 of whatever DAQ board you are connected to. I'm assuming that you are going to be doing some sort of RS-485 emulation so connect your transceivers to whatever digital pins you want. It's the external transceivers that you have to concerned about wiring the TX/RX + and - lines.
(2,933 Views)
