generate a digital output
I have some problems trying to generate a digital output, while reading an analog signal. I want to generate (trigger) a digital output, using an analog window input. When the analog signal reaches a value, then I want to set the digital output.
I would be glad if anyone could help me!
Joaquin
(3,214 Views)
Hi Joaquin,
I attach the most simple solution. Is this what you mean? If not, please specify the I/O in detail.
Hope it helps.
Pelle S
Account Manager
National Instruments Sweden
(3,209 Views)
Hi Pelle S,
thanks allot for your help. The VI you send me is exactly what I was looking for.
Joaquin
(3,150 Views)
