Multifunction DAQ
I get an error 10403 when I run the Count non ttl pulse vi.
I put some probes on my error path and then I highlighted the execution of the vi, and the error occured when the AI Start vi executes.I h/l the execution of the AI Start vi and the error occured when the first trigger config executed.We are now down to a Library function, and I can't find the problem.
(2,393 Views)
Thank you for contacting National Instruments.
This error usually occurs when you have your application configured to do something that your board physically does not support.
If you can provide a little more information about the hardware you are using, I may be able to narrow down the problem further.
Matthew C
Applications Engineer
(2,393 Views)
