I have a nidaq32.dll not found error. If i have already tried replacing the visa32.dll what else can i try?
I am working with VB6 on an application involving a PCI-6711 Analog output card. I now am in the phase of working on the install file. I have developed this application on an XP machine, and i am trying to install it on a Windows 2000 machine, but i get a "nidaq32.dll file not found" error when i try to run my program on the 2000 machine. I have looked in the System32 folder and nidaq32.dll is in fact in the folder. I am wondering if my install file (created using INNO installer) didn't register the file correctly, of if it has to do with the driver i am using on the PC. I have NIDAQ 6.9.3 installed on the 2000 machine and NIDAQ 7.2 installed on my XP machine.
Any help would be appreciated.
Gerry
(2,846 Views)
Hello GVanhorn,
The problem seems to be that you have different drivers in the systems. You might want to use the same version of the driver in both machine since that will install the same version of the nidaq32.dll.
(2,835 Views)
