I'm currently using an AT-MIO-16DE-10 card and I received the new NI catalog for 2003 and this card it is not there anymore.....Can you tell me what is the name of the replaced model ???
Another question: There is in the NI catalog a NIDAQ card with the same characteristics and performance of the AT-MIO-16DE-10 but with PCI bus slot
Thanks in advance
PILATUS Aircraft Ltd.
Andrea Cimadoro
Ing., R & D, Aerodynamics and Flight Simulation/
CH-6371 Stans
Switzerland
Direct Dial: ++41 41/619 6801
Switchboard: ++41 41/619 6111
Te
lefax: ++41 41/619 6452
E-mail: acimadoro@pilatus-aircraft.com
WWW: http://www.pilatus-aircraft.com
(2,574 Views)
Hello;
The best way to find a replacement for that board is through its main features, such as sample rate, input resolution, number of analog input, etc.
After you gather that information for the board you currently have (its Users Manual), you can cross check those specs on page 183 of the 2003 catalog. There is a table on that page where you can find the board that is the closer fit for your old hardware.
Hope this helps.
Filipe A.
(2,574 Views)
