I'm using a PCI-6070E...
I'm using a PCI-6070E 12Bit 1.25Ms/s card.....  Is the 1.25Ms/s spec only for 1 channel?  What is my sample rate if I acquire using all 16channels?  Thanks in advance...
(2,830 Views)
Hi Htch,
The multi-function DAQ cards have an input multiplexer that switches through all the channel inputs and feeds them to a single ADC. So the 1.25MS/s rate is the aggregate rate. The maximum sampling rate per channel will be 1.25MS/s divided by the number of channels used.
PBear
NI RF
(2,809 Views)
