Multifunction DAQ
I'm using the DAQ example, Arbitrary Waveform Generator, but need to add in an analog trigger. How do I do tis?
I need to output two square waves with a variable duty cycle. The arbitrary waveform generator is an excellent vi for this, but I also need an analog input to trigger this. How can I add one in? I want it to trigger off the rising edge of a square wave.
(2,447 Views)
Hello;
There is a Labview shipping example that shows how to configure an Analog Triggered Analog Output DAQ task.
You can find that example at Search Examples->I/O Interfaces->Data Acquisition->Analog Output->Triggering a Generation. The VI's name is Generate N Updates Using Hardware Analog Trigger.vi.
You can study how the trigger is applied on that VI, borrow the idea and implement that part on your VI.
Hope this helps.
Filipe A.
Applications Engineer
(2,447 Views)
