I need help sending a pulse stream.
I am using NI-USB-6229, with LabVIEW 8.5.  I am trying to send and receive a 16-bit pulse stream (with an additional start and stop pulse).  I need help getting that set up.  I want to pull each of the bits from a variable of some sort, so that when I send it out, I specify which bits should be hi or lo.  When I read in a similar signal (on another digital line), I want to be able to read whether each of the bits are hi or lo, and send them to LEDs on the screen.  I need the output to run repeatedly, from the NI-USB-6229, not from my computer.  I have not found something that gets me started, on the website or examples.
(3,164 Views)
In order to perform this operation with your device you will need to use a counter to generate a clock signal for your digital output. The digital subsystem does not have its own dedicated internal timing engine. Therefore, a sample clock must be provided from another subsystem on the device or an external source. The following two Developer Zone documents discuss how to accomplish this, while performing an input.
M Series Hardware-Timed DIO with Counter Clock Generation
DAQmx - Using a Counter as the DIO clock for M Series
The method in which you will build the digital waveform will depend on the type of variables you will be pulling this information from. Here is a tutorial on building a table of digital data.  In regard to reading in your digital data and displaying it on screen I would look at the Read Dig Chan.vi example which can be found in the NI Example Finder>>Hardware Input and Output>>DAQmx>> Digital Measurements. You also mention that you would like to have this output come from the hardware only. You device has a 2047 sample FIFO buffer which will allow for buffered output but I am unsure what you mean by “not from my computer” could you clarify on that.
JaceD
Signal Sources Product Support Engineer
(3,135 Views)
It is my understanding that I can set up the samples, and then let the NI-USB-6229 run continuously, once the hardware has received the set of bits desired, without relying on the computer to control it, to ensure that there is a dedicated control of the output, so that the timing will not be impacted by other operations.  Is this correct?
Melanie
(3,126 Views)
Hi Melanie,
Thank you for clarifying what you meant, I believe the this Knowledgebase articles titled Analog Output Regeneration Modes and Data Transfer Request Condition for Continuous Analog Output using NI-DAQmx will be great resources for you please review these documents and post back if you have any further questions.
JaceD
(3,114 Views)
