I want a continuous square wave by using USB-6002
Dear Seniors,
I want a continuous square wave signal same as that we generate from the microcontroller, So I try to generate the square wave by using USB-6002 and my sampling info is 1k for Fs and 1k for a number of samples. But when I use that output as an input and check the graph so I get repeated signal for every 1sec and it basically overlaps for every 1 sec. I need a continuous square wave that doesn't repeat itself it should be continued even I press the stop button.
Kindly help me, my project is stopped due to this reason.
Thanks in advance.
Ibrar Ali
(2,433 Views)
Accepted by Shesha12345
Do you mean you want to print out a continuous pulse by Counter Output?
Maybe there's something wrong with your code.
Please refer to the following attachment which is counter example provided by NI
(2,412 Views)
Dear Member,
Thank you so much for your consideration, I need the same thing by using Analog Output, It is possible, I mean I want to make a code such as that code generate square wave of a particular frequency and duty-cycle, and that wave should be continuous, such as when run button is pressed then generation started and it will stop when a stop button is pressed. And I need a continuous signal, no overlap signal, no delayed signal, no repeated signal at a particular time, that repetition is due to sampling. How I can generate that continuous square wave by using USB-6002 DAQ device.
Thanks.
(2,406 Views)
