I want to see the plot of input and output in the same chart or graph
I want to see the plots of input and output in the same chart or graph.What is wrong are there in my vi?
Message 1 of 12
(4,154 Views)
You are using a bundle function instead of the Build Array.
Also, you will only get a single analog read. Is that really what you want to do? Please don't use the run continuous button.
Message 2 of 12
(4,152 Views)
firstly,I really used a bundle.But It doesn't work.
Message 3 of 12
(4,140 Views)
I know a bundle does not work and that is why I told you to use the build array.
Message 4 of 12
(4,134 Views)
I tried array as well.But,It also doesn't work.Could you tell me what's wrong with my vi?
Message 5 of 12
(4,126 Views)
First of all, you did not replace the Bundle. REPLACE IT WITH A BUILD ARRAY!
Then, since the graph requires a 1D array of waveforms, simply right click on the Build Array and select 'Concantanate Inputs'.
Message 6 of 12
(4,124 Views)
Thank you very much.But,could you tell me why the time of input part couldn't choose continous rather than finite?
Message 7 of 12
(4,119 Views)
I could't see the answer.
Message 8 of 12
(4,113 Views)
I don't understand your question.
Message 9 of 12
(4,108 Views)
I mean,why choose the finit samples rather than continous samples in DAQmx timing.vi of input part.
Message 10 of 12
(4,106 Views)
