how to put waveform data to file
I try to put waveform data to file.But I failed.Could you tell me how to do it?
(2,822 Views)
It depends on what kind of file you are trying to write to. There are nodes that you can place in your block diagram called "Write to Text File", "Write to Spreadsheet File", "Write to XML File" etc. There is also a report generator toolkit that you can purchase if you are looking to write and customize files in Microsoft Word, Microsoft Excel etc.
Hope This Helps,
Doug B
(2,811 Views)
