I wish to change the background colour of a waveform chart
I wish to print the waveform so i require a white background to the waveform chart
(14,311 Views)
You can set the background property of the chart by using a property node. Set the property to Plot Area>>Colors>>BG Color, set the property to write and use a color box constant to set the background color.
I have attached a quick vi that does this.
Hope this helps,
Lilly
(14,311 Views)
thank you that helped me a lot,.
(13,667 Views)
Thank you a lot , Lilly .
Hy.
Luigi
(12,283 Views)
I look for the same, this is the fastest way: just using Set Color in Tools Palette:
https://sites.google.com/site/tanayroysite/articles/how-to-make-labview-graph-background-transparent
(5,622 Views)
