Thank you for this information. We have already been through this. Some basics are understood but we are still very unsure about implementing them. Still having problems as there is not much specifics in the ouline tutorial courses.
One suggestion that we have previously gotten was to incorporate a Shift Register function. After playing around with this we have come up with only a very minimum understanding of this function. If we use the Shift Register function and it shifts the array, would it be possible to pull information as to how many times that the shift register has been used? Essencially stating that if register was used twice than use sound file 2 and if register is used 3 times use sound file 3, ext. Would we be accurate in assuming that there is a function that could do this? If so could you help explain how to do this? Or if there is an easier way.
