Impedance Matching between NI 9203 and Pressure Transducer
I have a question about Impedance matching between NI 9203 and a pressure transducer with an option to select 100 Kohm or 1150 ohm load resistance.  The datasheet for NI 9203 states an impedance of 138 ohms.  What is the impact on measured pressure signal between 100 Kohm or 1150 ohm's pressure transducer options?
Message 1 of 1
(938 Views)
