Initializing FPGA memory in CRIO 9082
Hi, I have to use NI-CRIO 9082 along with NI-9269 for a custom signal generation application. I have the waveform values in a csv file. How to initialize the FPGA memory with the waveform values from csv file? Under memory properties->Initial values, there is an option to initialize the memory through initialization VI. When I select, new VI from template option, I am getting the attached block diagram, which contains a for loop with the number of memory locations specified as the loop count. It also says "the front panel caption for this array indicator must be 'Init Data Out' ". But I don't understand the logic behind this template. Could anyone help me how to add the waveform values from the csv file to the FPGA memory?  Thanks in advance..
Message 1 of 1
(508 Views)
