how to ouput a single pulse using CO?
Hello there!
I am using a PCI-6110 DAQ and the purpose is to synchronize a DO with some AO.something like this:
Now, im using AO/StartTrigger to trigger a DO,however,this works fine on PXIe-6341(another card for test),but unable to work on PCI-6110
there is an error -200077 and it asks me to change sampTimingType from SampTime to OnDemand,obvious there is no such thing in DAQmx Timing VI.
Finally I choose to use a Timing Node to set sampTimingType as OnDemand, and a new error -200452 come.
Is there a way to solve this problem?
Here I post a example VI :
(762 Views)
By the way,this VI would run on a LV2012 computer ,so some newer function may not work.
(758 Views)
Accepted by topic author lovlex123
PXIe-6341 is an X Series DAQ. It supports digital waveform.
PCI-6110 is an S Series DAQ. It does not support digital waveform and hence does not support sample clock timing and triggering for DIO. Some S Series support correlated DIO which allows you to use the sample clock from AI or AO, but PCI-6110 is not one of them.
Reference: National Instruments PCI-6110 Manual
https://tmesystems.net/
(736 Views)
Thank you for your help!
(691 Views)
