Input Signal for cDAQ9189
Hello! I am working on connecting Pressure Transducers to the cDAQ9189. I have the option to purchase pressure transducer with output of: 4-20mA, 0-5V, 1-5V, 0-10V, RS485. For some reason, I can't seem to find the documentation on the accepted (or preferred) input signal onto cDAQ9189. Any help would be appreciated - thanks.
(1,250 Views)
cDAQ-9189 is just a chassis. You need modules to connect your input signal.
Learn more about CompactDAQ Systems
https://tmesystems.net/
(1,242 Views)
Hello, the module we plan on using is NI 9205 with DSUB. Looking at the back of it, the specs are as follows:
32-Ch +-10V to +-200mV 16-Bit Analog Input
+-10V Ch-to-COM
60VDC CAT | Ch-to-Earth Isolation
Does that mean I should go with the 0-10V output signal Pressure Transducer?
Thank you
(950 Views)
Yes, 0-10V sensor is more suitable for NI-9205
(923 Views)
