NI 9361 filter
HI everybody,
I'm using a NI 9361 to get a velocity signal from several motors and I'm struggling with some glitches n the signal.
I found in the manual the following text:
Programmable Digital Filter
the NI-9361 has a digital filter on each of the digital input lines to filter unwanted glitches on the digital input signal.
You can configure the following filter properties for each of the input lines:
  • Enable or disable the digital filter.
  • Minimum pulse width of the input signal that passes through the filter
My question is how do I enable and configure the filter? I do not find any possibility in NI MAX or Labview.
Karsten
(623 Views)
Accepted by topic author pho_nox
Try the method in Enabling Digital Filtering Using Dummy Counter
https://tmesystems.net/
(616 Views)
