Input analog signal with trig signal on DAQPad6020E
I would like to record an input analog signal in continous with trig signal on falling edge. The frequency trig is 3.87hz (258ms)with 5V level. In fact I want to record the input analog signal every 258ms.
I use a DAQPad6020E and the VIs "AI-Config", "AI-Start" and "AI-Read" with a "digital A" trigger type (PFI0/TRIG1 on block connectors) and record datas in a file.
I use the following configuration:
- sampling rate= 100000 S/s (max rate DAQPad6020E)
- minimum scan= 25200 pts
When I read the datas I notice that the gap between the first point of the first acquisition and the first point of the second acquisition is 1016ms and not 258ms like the trig.
I change the configuration:
- sampling rate= 10000 S/s
- minimum scan= 2520 pts
The gap is now 516ms (it correspond to two trig)
An other configuration:
- sampling rate= 155 S/s
- minimum scan= 40 pts
The gap is 516ms (it correspond to two trig)
I use also the VI "AI-Wave" but the results are the same.
I don't understand what happend. Maybe it's due to the card limits ?
Thank you for your answer.
(3,633 Views)
A trigger is an external stimulus that initiates one or more instrument functions. Trigger stimuli include a front panel button, an external input voltage pulse, or a bus trigger command. The trigger may also be derived from attributes of the actual signal to be acquired, such as the level and slope of the signal.
A trigger is not a clock.
If you want acquire with a specific clock, I advise you to use external clock. Instead of using your signal as trigger, use it as external clock.
Have a look at "Cont Acq & Graph Ext Scan Clk - D trig.vi" example. This example is provided with LabVIEW (Help >> Example Finder).
Here a tutorial about external clock acquisition :
http://zone.ni.com/devzone/conceptd.nsf/webmain/7d8eaea1d87cfb2686256802007b8c52?OpenDocument
Isabelle
Ingénieur d'applications
National Instruments France
(3,621 Views)
Thank your for your answer Isabelle.
But I'm not sure that the VI "Cont Acq & Graph Ext Scan Clk - D trig.vi" is appopriate.
I would like to acquire the input analog signal every 258ms (with my trigger) and with scan rate 10000 S/s for example.
I would like that each edge falling of my trigger initiate the acquisition.
Is it possible to take the scan of labview (10000 S/s for example) and external clock (my trig) to have every 258ms a measurement of my analog signal (with 2580 points)?
(3,616 Views)
If i understand you, you want to do finite acquisition every 258 ms.
The first example uses 2 devices (multifunction DAQ and counter/timer device):
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=BFE6E379D5807506E034080020E74861&p_node=201213&p_rank=&p_source=Internal&p_submitted=N
But you can program both devices in DAQmx, if you have NI-DAQ 7.3.
The second example only use the multifunction DAQ device.
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=B45EACE3F09F56A4E034080020E74861&p_node=DZ52335&p_rank=&p_source=Internal&p_submitted=N
Isabelle
(3,597 Views)
Merci pour votre aide, mais je n'arrive pas à accéder aux exemples que vous m'indiqués : impossible de se connecter aux adresses web !?
cordialement,
Christophe
(3,565 Views)
FYI, DAQmx does not support the DAQPad6020E...
Peter
(3,556 Views)
Bonjour,
Vous pouvez voir la page www.ni.com/examples.
Salutations,
Isabelle
(3,500 Views)
