Installed LABView 9.0, with DAQmx 8.8; updated to 8.9.5, still problems.
(3,478 Views)
I'm attempting to upgrade to LABView 9.0, but only have DAQmx version 8.8.  I updated to DAQmx version 8.9.5, but still don't have the supported VIs available in the block diagram.
Any help is appreciated.
(3,473 Views)
Hi Ricky,
You are correct, DAQmx 8.9.5 is the first version of the driver to support LabVIEW 2009 per the following KB. I recommend installing the latest version of DAQmx, and make sure you have the support selected for LabVIEW 2009 like the attached image.
Hope the second time is the charm.
Glenn
(3,450 Views)
