Integrate Acceleration to get velocity using Time Domain Math
I'm trying to do something simple but haven't found the answer to my problem.
I have a loop that takes torque as an input and calculates acceleration; see attachment.
I'm trying to calculate velocity using acceleration.
I used continuous integration function of Time Domain Math, plugged acceleration in as the signal but the velocity it outputs isn't correct.
If the acceleration is 1 in/s^2, the velocity that is calculated is tens of thousand in/s within 1 second. That's not right.
What am I doing wrong?
(3,937 Views)
Accepted by joecap5
Looks like I posted this in the wrong place. Not sure how to delete it though.
(3,923 Views)
Hello Everyone,
Incase you are looking for the solution to this post.  The correct thread being worked on is here.
Paul C.
(3,913 Views)
