10-11-2016 10:48 AM
I get an intermittent error -229770 when creating a Task in my LabVIEW software.
My application will work fine for a day or so, and then i will get this MIG software error.
DAqmx TAsk name is Perf_Cst utilizing CAQmx Create Task.vi. I only get this erro on the cDAQ 9132. I've never received this error utiling LabVIEW and this same application on my DELL Labtop.
Help!![]()
Solved! Go to Solution.
10-12-2016 06:00 AM
I was able to cancel the error by setting the execution from "Time Critical" to "normal" and preferred execution system from "data acquisition" to "normal". I changed the execution previously while experimenting. ![]()
10-12-2016 08:59 AM
I'm getting the error again! Evidently still intermittent? However, I can't make it go away this time! I was able to run my source code successfully and build my application. My EXE runs without error, however, when I run the sourcecode, I get the MIG error as stated in the attached file. The attached file contains a simplistic Create Task function, which continuously generates the MIG error. I ran this simple VI yesterday in a continuous loop without issue. Shutting down the cDAQ-9132 and restarting has no effect on the error. HELP!!!!!!
10-13-2016 06:38 AM
Email to NI App Support:
Hey Hi Will,
I thought it was fixed, however, the next day it popped up again. I did repost following the original posts. I noticed some posts recommending reloading LabVIEW. I’ll try that when I get the chance. I’m off to the next project right now. Interesting enough, I made an EXE before the error popped up again and my application works fine. So, I was able to launch and go on to the next endeavor.
Will, I just ran the VI again on the cDAQ 9132 and consistently get the MIG error. I ran it on my laptop with the same LabVIEW load and I don’t get the error. I went to run in on my cDAQ 9133, only I found I don’t have LabVIEW installed because of memory limitations when utilizing other applications. Obviously, since I didn’t have LabVIEW installed I couldn’t run it. I went back to the cDAQ 9132 and built an EXE. Surprisingly, the EXE runs without any error on the cDAQ 9132; original place of error.
I also notice the VI runs without error if I run it independent of a lvproj on the cDAQ 9132. If I run it from a project, I get the MIG error. I’ll reload LabVIEW using LabVIEW 2016 Prof System and see what happens.
Thanks! ~ Skip
10-14-2016 09:39 AM
I followed the instructions offered by NI App Engr Will and reset MAX. The independent VI, VI in the project, and the EXE, (All same simple VI which merely creates and clears a Task in LabVIEW) now all work error free! ![]()
01-20-2017 03:32 AM
Gettting the same problem. What do you mean you reset MAX?
Seán
02-05-2017 09:05 PM
I did a reset configuration from the MAX pull down menu. I forgot which tab it's located under. I think far right, maybe help. Then restarted laptop and reloaded configuration file. Sorry, don't currently have LabView with me. Watching Super Bowl. Lol
Seán
