control pxi 1010 chassis with mxi controller
I have an old pxi1010 chassis that I want to put back into service.  It was originally run with an embedded pc controller, but the embedded pc is so old that I can't do much with it.  I would like to be able to control the chassis and its scxi and mxi daq with an external pc (maybe laptop).  Can I run the pxi1010 with a mxi controller?
(3,427 Views)
Controlling the PXI chassis with an external PC using MXI will not be a problem.  The only thing that might be an issue would be the BIOS.
Andy L.
(3,407 Views)
Can someone at NI repair the link for the list of PCs
(2,843 Views)
Hey Jonny,
It looks like this white paper below has the information from those links.
Tips to Help You Successfully Use NI MXI-Express Controllers - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0MKCAY&l=en-US
JY
Application Engineer, RF and Communications
(2,832 Views)
