Internet of things: NI 9181
I have an NI9181 that I' am connecting through nidaqmx python and flask.
If I connect my laptop to the same network that the chasis is, I can access it. No problem on this part.
My question is: if I know its IP address can I read out the information that is accesing (through its NI9234), essentially, If I am in a different network, can I access the device data feed with the following scheme?
 I am just starting in such matters, I don't know if this is possible and how.
(1,903 Views)
Yeah, that is possible as long as there is a network route between network A and network B. But if one of the network is a private network with packet filtering or firewall blocking certain ports, then the IT infrastructure has to open up a network route and unblock the ports for it to work.
I have acquired data from another continent using Ethernet cDAQ chassis. The latency is really bad but it is possible.
(1,814 Views)
@Jerry_X, thanks for answering, any good tutorial or documentation that you could suggest to a newbie like me?
The way I do it is having the python program with a computer and then using ngrock to communicate from one network to another (with another computer).
(1,792 Views)
Well, these are the basics.
  1. We have to know IP address of the machine in network B and the Ethernet cDAQ chassis in network A.
  2. These IP addresses should be able to ping each other.
  3. There is this knowledgebase for troubleshooting Ethernet cDAQ connection issue: Troubleshooting Network cDAQ Connectivity Issues - National Instruments (ni.com). These are the ports required to be open for Ethernet cDAQ communication:
    • HTTP:80 (configuration only)
    • TCP:3580
    • TCP:31415
    • UDP:5353(configuration only)
    • TCP: 5353(configuration only)
    • UDP:7865 (configuration only)
    • UDP:8473 (configuration only)
(1,766 Views)
Thanks again for your input, @Jerry_X I will check this info out
(1,763 Views)
