The same DAQ assistent in 2 different SUB VI
Hello everyone,
in my main program I call 2 Sub VIs and they contain a DAQ assistant with the same task. The execution of the first Sub VI works without problems, the second one does not start the DAQ assistant. If these are performed separately, however, they have no problem.
How can I solve? Thank you all
(947 Views)
Solution - DO NOT EVER GO NEAR DAQ Assistant
Learn and code with DAQmx - https://www.ni.com/en-us/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-ha...
Santhosh
Soliton Technologies
(945 Views)
