Interrupt Driven (Asynchronous) Digital Input from NI6008
I want to set up my NI-6008 OEM to "interrupt" i.e. call a Windows Callback function, when a digital I/O line changes state. I looked at the example ReadDigChan-ChangedDetectionEvent.c which is sample source and modified it slightly for my hardware.  The code is in c++ and runs on Windows XP.  Am I doing something wrong in the setup or is the 6008 board incapable of interrupt driven I/O?
The code in question is:
DAQmxErrChk (L"DAQmxCreateTask", DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (L"DAQmxCreateDIChan", DAQmxCreateDIChan(taskHandle,DINPSTR,"",DAQmx_Val_ChanForAllLines));
//DAQmxErrChk (L"DAQmxCreateDIChan", DAQmxCreateDIChan(taskHandle,DINPSTR,"",DAQmx_Val_ChanPerLine)); tried this, didn't help
DAQmxErrChk (L"DAQmxCfgChangeDetectionTiming", DAQmxCfgChangeDetectionTiming(taskHandle,DINPSTR,DINPSTR,DAQmx_Val_FiniteSamps,1));
DAQmxErrChk (L"DAQmxRegisterSignalEvent", DAQmxRegisterSignalEvent(taskHandle,DAQmx_Val_ChangeDetectionEvent,0,ChangeDetectionCallback,NULL));
DAQmxErrChk (L"DAQmxStartTask", DAQmxStartTask(taskHandle));
"DAQmxErrChk" is a macro defined in the line below
#define DAQmxErrChk(functionName, functionCall)if(DAQmxFailed(s_iError=(functionCall))) {s_iLine = __LINE__; s_szFunctionCall = functionName; goto Error;} else
The error occurs on the call to DAQmxCfgChangeDetectionTiming
A call to  DAQmxGetExtendedErrorInfo through the macro returns
2011-04-15 @ 14:01 Module:  InitializeIO, Line:  85
Function:  DAQmxCfgChangeDetectionTiming
 Requested value is not a supported value for this property.
Property: DAQmx_SampTimingType
You Have Requested: DAQmx_Val_ChangeDetection
You Can Select: DAQmx_Val_OnDemand
Task Name: _unnamedTask<0>
Status Code: -200077
I'm attaching the c++ source file that contains the NI DAQmx calls for your review as well.
 Any help would be appreciated.  Thanks is advance.
- Neil Shore
(4,178 Views)
Accepted by LaserShore
It doesn't look like the 6008 supports change detection. You could try using a parallel loop structure to monitor the state of the digital line and then putting a small delay in a loop to monitor your DI and base your change on that.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAqXSAW&l=en-US
Jake H | Product Manager
(4,164 Views)
Hi Jake,
Thanks for your reply.  Thanks for your link that confirms my understanding.
Would you have a quick suggestion as to what NI USB device would be the closest to the 6008's feature set, I/O lines A/D, and D/A, and DOES support change detection (interrupt driven digital I/O)?
Thanks again for your help.
- Neil Shore
(4,159 Views)
Hi Neil,
Assuming you stick with USB, any of the hardware timed products should detect the interrupt you're looking for. I wouldn't want to recommend anything specific without talking about your application a little more. If you want to send me your contact information I can have someone get in touch with you and discuss some of our different products.
(4,135 Views)
