Interrupt signal with DAQ-STC
I want to use an interrupt service routine with a PCI6025E using the DAQ-STC.
On which pin can I input my signal (perhaps on Gate0) and which registers
must be configured. I'm not interested about how to create an ISR, just the
register value to generate an IRQ on the PCI-Bus.
(3,013 Views)
The DAQ-STC Technical Reference Manual (downloadable) may help you. A quick flick through my copy suggests the section you want is 8.4.1.3 Pass-Through Interrupt and it looks like input pins IRQ_IN<0..1> are what you need, assuming your card supports this functionality.
Jamie Fraser
(3,013 Views)
