04-01-2012 06:38 AM
I have a PCI-6014 I use to test NI-DAQmx scenarios occasionally. I have just installed NI-DAQmx 9.50f2 along with the existing traditional NI-DAQ 7.44. MAX sees the PCI-6014 and installed its driver but only NI-DAQ can configure acquisition, NI-DAQmx does not see it nor in MAX, neither in LV. So question is - is PCI-6014 no longer supported in NI-DAQmx or is there another problem?
If 1st is the case, was NI-DAQmx 9.40f1 the last supporting B series DAQ cards (PCI-6014)?
Thanks in advance,
04-01-2012 09:29 AM
You can always find a list of compatible devices in the readme. For 9.5 that's here.
I seem to remember that a device can only be used in Traditional DAQ or DAQmx, but that may be incorrect.
