Is it possible to connect a 4-20ma signal directly to a PXI 6025E Daq Card
Is it possible to connect a 4-20ma current signal directly to a PXI 6025E Daq Card
(2,854 Views)
Set the 6025E to differential input, add a 250 ohm precision resistor across the input. This will give you a 1 - 5 volt input that correlates to the 4 - 20 ma signal.
Greg Bush CLAD
(2,849 Views)
