Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is it possible to connect a 4-20ma signal directly to a PXI 6025E Daq Card
sandeep v
Member
01-31-2005
12:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to connect a 4-20ma current signal directly to a PXI 6025E Daq Card
0
Kudos
Message
1
of 2
(2,853 Views)
Reply
Re: Is it possible to connect a 4-20ma signal directly to a PXI 6025E Daq Card
bushman
Member
01-31-2005
07:51 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Set the 6025E to differential input, add a 250 ohm precision resistor across the input. This will give you a 1 - 5 volt input that correlates to the 4 - 20 ma signal.
Greg Bush CLAD
0
Kudos
Message
2
of 2
(2,848 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
