Is it possible to use a wireless USB dongle couple with IN-USB-6009 ?
If it's possible to use a wireless USB dongle couple with IN-USB-6009 we can make a telemetry system with 250 Euro.
It would be fantastic!!!!
Wisair Wireless USB adapter set:
Wireless USB, WiMedia Standards
• Based on Certified Wireless USB,WiMedia PHY and MAC Specifications
• Association using direct dongle attachment to PC
• Point-to-MultiPoint support
• Interoperable with other Certified WUSB products
• 3.168 to 4.752 GHz (WiMedia band group 1)
• PHY channels 9-15
• Output power: -41.3 dBm/MHz
General
• 128-bit AES security
• FCC and Japan regulation compliant
• Software drivers: Windows® Vista/XP
Message 1 of 9
(4,295 Views)
yeah,  but does the unit supply power to the USB device is the question?
Message 2 of 9
(4,282 Views)
Hi Zinnium,
yes my idea is to use batteries and a voltage regulator to supply power to the system.
Maybe I can use I can use the same supply to power sraingauge bridges and precision (measurements) amplifier.....
Message 3 of 9
(4,259 Views)
Take an IPOD or a USB memory stick that has light on it and plug it into it.
If it charges or lights up;  you can do what ever you want.  :smileywink:
Message 4 of 9
(4,245 Views)
Hi all,
I think you should consider this KB. Also be sure that you must use a device that is supported by the Microsoft Bluetooth Stack or the new WIDCOMM stack.
I hope this helps!
Bye!
Licia
Message 5 of 9
(4,219 Views)
I must clarify:
1) The connection should be done by a Wireless USB dongle (not a USB hub and not Bluetooth)
2) IN-USB-6009 and Wireless USB dongle should be powered by batteries.
I ordered the Wireless USB dongles and I have a  IN-USB-6009.
In a couple of week I will try........
Message 6 of 9
(4,217 Views)
Good luck on it.
I was actually thinking about it today, and it should work since the USB port on it is capable of writing to a flash drive.    It means it has to be able to provide power to the port to power the flash drive.
My experiance in the past with different items ahs been hit or miss.  Some devices did supply power while other did.
Message 7 of 9
(4,200 Views)
So whats the story???  Did it supply power and work or did you have to do something else?
Message 8 of 9
(4,127 Views)
I connected the Wisair dobgle to NI-USB-6009 and I used an external +5V.
I was able to record max. 20 minute 8 channels at 1kHz per Ch. but at the end the recording stop due to an error (from SignalExpres).
Reducing the sampling rate don't help!!!!
I will try to write my hown acq softer to be able to handle the errror.
Message 9 of 9
(4,112 Views)
