Multifunction DAQ
Is the PCIe6321 card the express version of the PCI6221 card?
Hey,
is the PCIe6321 card the express version of the PCI6221 card?
thx
Koen.
(2,713 Views)
Accepted by kdCMC
Not exactly, but it's very likely a more than adequate drop-in replacement.
The 63xx series boards are the newer X-series design with some improved specs and several significant improved capabilities.  I can think of only 1 relatively obscure behavior that I consider *worse* under X-series.
Double-check the specs and pinouts, but you're very likely to be able to substitute seamlessly while gaining some benefits.
-Kevin P
(2,693 Views)
