Is there a C-Series 12 V analogue output module?
Hi all,
A customer wants the ability to output up to 12 V (variable voltage). The system is quite simple, so CompactDAQ is ideal; PXI would be an overkill.
However, I can only find modules that output up to 10 V on the AO page (http://sine.ni.com/nips/cds/view/p/lang/en/nid/208785  ). Is there a C-Series module that can output 12 V?
Thanks!
Certified LabVIEW Developer
(4,194 Views)
Output current needed?
Output voltage accuracy/stability/... needed?
Output freq? Settle time? ....
You can try two channels of a  9269
https://www.ni.com/en-us/shop/model/ni-9269.html
If no card available: Analog amplifer? Or if only 2+x V to 12V is needed : Just use a (Z)-Diode (and a R + supply)  or another floating voltage source (battery?)  to shift the output voltage?
Greetings from Germany
Henrik
LV since v3.1
(4,171 Views)
Thanks for your suggestions, Henrik.
I think op-amps are the way to go 🙂
(4,118 Views)
