Is there a VI for USB-6008 that works in LV7.0
I have been using Labview 7.0 and just bought a USB-6008.  It appears to be operating correctly with Signal Express, but Signal Express 2.5 won't create code for LabView 7.0.  I have been using a USB DAQ from MCC and it is working well with their library of VI's.  Is there a VI available for the USB-6008 that will run under 7.0?  Or what is the easiest way to get it to run with 7.0.
Benchtester
(2,858 Views)
Accepted by benchtester
For 7.0, the latest version of DAQmx that you can use is 8.1. Since you just bought the 6008, you probably have a much newer version installed. Uninstall the current driver, download 8.1, and install that. You should then have a Measurement I/O>DAQmx palette. On their will be the DAQmx functions and the DAQ Assistant. You should also have numerous examples to look at.
(2,848 Views)
