Is there a low-pass filter that is compatible with the SC-2040?
I am presently using external anti-aliasing filters with my SC-2040, SSH card. Is there a low-pass filter module that is compatible?
(2,619 Views)
Greetings,
Unfortunately, there are no lowpass filter modules compatible with the SC-2040. One option you may want to consider is an SCXI system with an SCXI-1140 (8-Channel Simultaneous-Sampling Differential Amplifier) cascaded with an SCXI-1142 (8-Channel Bessel Lowpass Filter). Below are links to information regarding these modules:
SCXI-1140
SCXI-1142
Good luck with your application.
Spencer S.
(2,619 Views)
