How do I get this to run only once
I am using Labview and an E series DAQ to control a stepper motor. I downloaded a finite pulse generator to send out the number of pulses I need when a case is selected, but now my problem is that the vi keeps repeating the finite pulse generation, so it sends out 10 and then 10 and then 10... it keeps going. I need a way for 10 pulses to be sent out and then no more until the case is changed.
(2,487 Views)
If you use the example that ships with LabVIEW 6.1, titled "Finite Pulse Train (DAQ-STC)," one train of a specified number of pulses will be generated and then the VI will quit. If you are importing this example VI into your own custom program, you need to ensure that it is not called from within a while loop. Perhaps that is why you are seeing the pulse train repeating itself.
This example can also be found by clicking on the following link:
http://eagle.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E6CD56A4E034080020E74861&p_node=DZ52328&p_submitted=N&p_rank=&p_answer=&p_source=Internal
Justin Britten
(2,487 Views)
