Is there a simulator for E-Series Cards?
Hi Folks,
I developed an application that uses an E-Series card. To make any updates, I need to connect remotely to the system that has the card. I'd like to try several programming techniques in a controlled environment first, then move the program to the actual system, so I need to be able to simulate the E-Series card.
Mike
(2,961 Views)
Mike,
Unfortunately, it is not currently possible to simulate an E-Series card. The best way to program a DAQ application without having a board in the development computer is through the use of RDA, but it sounds like you have already done this, and you are now looking for another solution. Sorry I can not help.
Good luck with your application.
Spencer S.
(2,961 Views)
Hi Spenser,
Thanks for the answer. Actually, I was using pcAnywhere to run the remote machine. I didn't realize I could change a program remotely. I cannot find anything in the book about doing this.
Mike
(2,961 Views)
Mike,
Below are the links to a couple of tutorials concerning RDA:
Networking Two PCs for Remote Data Acquisition
Developing Networked Data Acquisition Systems with NI-DAQ
Spencer S.
(2,961 Views)
