06-22-2009 06:45 PM
Digging up old bones here, but have a question regarding building the installer with the Runtime 5 choice. I am using 8.6.1 and DAQmx8.8 in development.
My production target machines do not need any of the items left out of the Runtime 5 and all but one of my installs worked with no issues. However, the one install that is giving me problems is on a machine that also has LV8.5 development environment and the DAQmx drivers that came with LV8.5.
My real question is can the DAQmx runtime 8.8 drivers co-exist with the full DAQmx drivers included with LV8.5 (DAQmx 8.6 I believe) or will there be some conflicts or missing items causing problems?
My application is locking up and we got an error from Visual C++ Runtime Library that showed the program nimxs.exe was terminated unexpectedly when we restarted the PC at one point after install. This is what is leading me to believe that the driver versions cannot co-exist.
06-24-2009 10:16 AM
Hi, Troy.
Just to review:
The full DAQmx and runtime DAQmx can coexist.  The LabVIEW runtime engine will exist separately, and the target
machine will be able to run the executable using the runtime it was
built with.  You can also install as many different versions of runtime engines on a machine as you
would like, and they will not interfere with one another.  For example, if
you want to send someone a LabVIEW executable built on LabVIEW 8.6, and
they are already utilizing LabVIEW executables built with LabVIEW 6.1.
The new 8.6 LabVIEW runtime engine will exist next to the older LabVIEW
6.1 runtime engine on the target machine, and nothing will be
overwritten or conflict.
Here is a good KnowledgeBase for information regarding which version of LabVIEW Runtime should be used. The Related Links on this KnowledgeBase are also very good.
The issue at hand seems unrelated to the versions of the Runtime and full versions of DAQmx. Make sure to add the following services to the exception list of any firewall software: NIMax.exe, nimxs.exe, NiAsstnt.exe, nipalsm.exe, nidevmon.exe. I think there may be a Database corruption error. Go through the steps in the following KnowledgeBase and see if this solves the issue: Why do I get a MAX Database Corruption Error?
