PCI 6503 - no supported device found
Hi, i have a problem with the PCI-6503 under XP (Labview 8.2; NIDAQmx 8.5). THe board is correctly installed (i can see it both in the pc hardware explorer both using MAX). Using max the board is named NI PCI-6503: "Dev-1".
When i try to create task ( i need to generate an analogue output voltage ) MAX shows me: no supported device found.
any suggestions?
regards
(3,301 Views)
Of course you get that message. Do you not know what type of board that is? How do you expect to get an analog output?
Message Edited by Dennis Knutson on 06-24-2009 07:41 AM
(3,293 Views)
i'm sorry... a big mistake...
thanks
(3,286 Views)
