 martim
			martim
			06-24-2009 07:47 AM
Hi, i have a problem with the PCI-6503 under XP (Labview 8.2; NIDAQmx 8.5). THe board is correctly installed (i can see it both in the pc hardware explorer both using MAX). Using max the board is named NI PCI-6503: "Dev-1".
When i try to create task ( i need to generate an analogue output voltage ) MAX shows me: no supported device found.
any suggestions?
regards
 Dennis_Knutson
			Dennis_Knutson
		06-24-2009
		08:41 AM
 - last edited on
		03-05-2025
		03:19 PM
 by
		 Content Cleaner
			Content Cleaner
Of course you get that message. Do you not know what type of board that is? How do you expect to get an analog output?
06-24-2009 09:48 AM
i'm sorry... a big mistake...
thanks
