Is there an adapter to fit a full-height PCI card into a low-profile PCI slot?
I'm trying to find an adapter that will allow me to use my older PCI-1200 DAQ card (Full-height) in a new Dell Optiplex 745 w/ Desktop case, which has only half-height slots.
Thanks.
(6,030 Views)
Hi SysAdminPA,
Thank you for posting on the National Instruments forums.
National Instruments does not sell an adapter that allows you to use a full profile PCI in a low profile slot.  We also do not support PCI extenders since they usualy do not completely follow the PCI spec and therefore will cause errors with our DAQ devices.
If you must use a computer with a low profile slot, then the best option for you would be to get a USB DAQ device.  The USB-6221 is a DAQ device that is similiar to the 1200 with 8 extra analog inputs.
Thank You,
Nick F.
(6,016 Views)
Any update on this?
What if you need to run a real-time PC with DAQ and that PC requires a 1/2 height card?
USB DAQ devices don't work with real time.....
I guess best option is cut a slot in the top of the PC to allow the DAQ card to stick out the top? 😉
In order to keep up with technology (i.e. 2005) NI really needs to:
1) Make RT work with USB Daq devices
2) Make 1/2 height DAQ cards.
(5,608 Views)
I did some research, back around the time I posted my question in 2007, and I found a "Dual PCI Riser" (Dell P/N 310-8346), from Dell (it was for a Dell Optiplex 745DR). It's still available from Dell, for ~$35.
This adapter plugs into one of the slots in the case and lets you mount two PCI cards sideways. See the Dell website for more details.
However, as it turns out, for me it didn't work because there was a graphics card in the way on the motherboard. But it may work for you.
(5,605 Views)
That might just work!!! I have the room as an AGP graphics card is not needed for the RT box.
Thanks for the lead.
(5,587 Views)
