Is there any DAQ that can suits my case
I need a DAQ to generate  2 or 3 continuous DC voltage and 1 pulse output. The main issues that should be considered are as following:
1)the outputs should work individually
2)the dc volatge I need is one about 30volt and the other about 8 volt( I'm thinking about an amplifier but if signal conditioning can work, it would be great as well)
3) I know that initially the data will be saveed in buffer and then the output generation will start(in other words there is delay) and continues untill the specifications are changed or will be stoped by user,here my question is that if after any changes in specifications we counter with buffer delay? and if there any way to cancel this delay?or decreased it as least as possible?
4) I need one digital input for recieving a TTL pulse
I need at least 1.5Ms/s transfer rate and for sure a good price.
Do you have any suggestion for me?
(2,930 Views)
There are a number of different options for you. What format are you looking to use (PCI, USB, etc.)?
For any pre-sales questions like this, we can best support you if you call NI so that we can discuss this with you and help you find the right device for you.  Just call (888) 280-7645, or you can go here and have one of our sales people call you.  If you'd prefer to keep this discussion on this forum, let me know.
Mark E.
(2,897 Views)
