NI-DAQ Traditional test panels will not run consistently for regular users
Our labs are using a PCI-MIO-16E-1 DAQ board.
When running the latest release of (Fall 2009) NI software (Labview 2009, CVI, Drivers, etc.) regular users (non-admin) are having varied success in running the MAX test panels for the traditional device.  It will work fine for one user and the next user will run into the 'grayed out' test panel issue.
I have granted full access to C:\Program Files\National Instruments as well as to C:\Windows\niconfig.daq (which helped with the issue in previous versions.
I have tried running SysInternal's 'Process Monitor' to see if there were any obvious permissions issues, but this doesn't explain why it works for some and not others when the users have the exact same rights on the local machine.
Windows XP Professional with SP3
Dell Optiplex 960
4GB Ram
160 Gig HDD
Any ideas?
(3,757 Views)
Have you downloaded the LabVIEW 2009 patches?  There have been 2, one of which addresses permission issues.  Both patches are encompassed in the second patch linked here.  I recommend installing the patch first to see if the behavior is remedied.  Hope this helps!
h_baker
(3,727 Views)
We are running the latest f2 patch and it has not resolved the issue.
We still have sporadic test panel access issues with non-admin accounts.
-Brian
Message Edited by coates on 10-27-2009 12:07 PM
(3,714 Views)
Hi Brian,
Try the steps in this document that detail how to give non-administrators full control over NI products. This should eliminate the need to give them access to particular programs.
h_baker
(3,695 Views)
The steps outlined in the document have already been followed (as mentioned in my initial post).  Users have full access to the NI folder but still seem to run into the issue.
-Brian
(3,680 Views)
Unfortunately, if installing the patch and following the permissions knowledge base did not resolve the issue then it may be a LabVIEW 2009 and Traditional DAQ issue.  Traditional DAQ has not been updated since 2007 so if there were any changes to the way it is being handled, then there may be things that do not work as expected.  I apologize for any inconvenience this may cause but your card is supported by the latest version of DAQmx which may be worth pursuing, especially since there is no plan to develop Traditional DAQ.
h_baker
(3,646 Views)
