Kernal_Data_Inpage_error
HI,
I am using PCI-MIO-16XE-10 card on my PC.
I loaded NI-DAQ software version 6.9.3 on my PC.
My operating system is windows XP.I went into Measurement and automation and configured the DAQ.
I even tested the Resources and it gave me a positive feedback. I connect my PCI-MIO-16XE-10 card to a NI-SCXI-1000(SCXI-1141,SCXI-1305). The operating mode is parallel. All the setup looks fine but after using my PCI-MIO-16XE-10 card for some time. I would get an Kernal_Data_inpage_error and my operating system would shut down.I am attaching the full error.
Any help would be appreciated.
Thank in advance,
Rann.
(2,945 Views)
Rann,
The error you are receiving is not a National Instruments error, nor is it most likely caused by our hardware. This is a Windows error and Microsoft will be able to provide you with the best solution.
However, I have done a little research and found the following information for you ...
Stop 0x0000007A or KERNEL_DATA_INPAGE_ERROR
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/prodtechnol/winxppro/reskit/prmd_stp_fvlq.asp
Microsoft states that this is a memory (RAM or ROM) related error and might be due to incompatible disk or controller drivers, firmware, or hardware.
Viewing some (non NI) posts on the web I noticed users complaining of these errors in XP. For some users the problem was due to faulty hard drives ship
ped with the PC.
Here's another external web site post on this error.
Bug Check 0x7A: KERNEL_DATA_INPAGE_ERROR
http://www.osr.com/ddk/ddtools/bccodes_2vjb.htm
Justin Britten
National Instrumenets
(2,945 Views)
