Kernel source problem while installing VISA
I am using Suse Linux 11.1 . While trying to install LV Professional I found the following error. LV was trying to setup VISA
******************************** ERROR ****************************************
* Kernel source in /lib/modules/2.6.27.7-9-default/source does not appear to be
* configured for the 2.6.27.7-9-default kernel.
* Configuration of kernel source is required to continue installation.        *
* Refer to the README file for the product you are installing for information *
* about configuring your kernel source.                                       *
Though LV is up and running, I would like to install the VISA.
Please advise what can be done.
Thank you.
H.
(3,350 Views)
Hi H,
You might want to try installing the latest version VISA from the installer available on our website, you can find it here:
NI-VISA 4.5.1 - Linux, Mandriva, RedHat, SUSE
Hopefully this version will install for you, let us know what you find.
Scott M.
(3,328 Views)
