LD-11637 CLI Linux not able to add as net device
Hello.
I'm trying to add a LD-11637 as a netdevice to a linux system. I'm using nidaqmx version 21.3.0f167, and the device should be supported.
I can detect the device:
kaius@nuc-1:~$ nidaqmxconfig --find-net-devs -v
Hostname Type IP Address
FD-11637.local NI FD-11637 192.168.10.151
But when I try to add it:
kaius@nuc-1:~$ nidaqmxconfig --add-net-dev 192.168.10.151
Failed
Error -201247
Device cannot be created in MAX because a driver could not be found for the device. You may need to upgrade NI-DAQmx.
Does anyone have any clue about this?
~kaius
(1,324 Views)
Accepted by ~kaius
According to NI-DAQmx for Linux/x86 64-bit Architecture Readme the FD-11637 is not supported
__________________________________________
The best way to thank, is to give KUDOS
(1,288 Views)
